hehe.. I've posted this numberous times, but I KNOW the LSN is too lean.. It just wont run if I start richening it up.. Like I said before, any more than a 1/12 turn (richer) at a time and it'll die as soon as I give it any throttle. (And once I give it that 1/12 of a turn, I have to run it for quite a while before I can richen it again, else it dies and I have to start over by leaning it 1/2 a turn again (that's not a typo.. If I richen it 1/12 of a turn too much, it'll die and I have to lean it a HALF turn before it'll run right again. Then I can start over richening it 1/12 at a time) I also tried closing the idle gap some more today, thinkin I might of been imagining the 1mm gap, but when I close it ANY more, it barely starts, and only idles for about 10 seconds and dies.. So I put it back where it was.. But the good news is, I ran another tank through it today, and at the end it was running pretty good, all but for the idle still being too high. When I was done I checked the needles, to see where I was at.. The LSN was 2 3/4 out (Only 1/4 turn to the lean side, from stock, where as when I first started it would'nt run at all unless I was 3/4 of a turn lean) So, it's getting there, slowly but surely.. The HSN was 2 1/4 out, which puts it at 3/4 of a turn lean, from stock.. If I richen the HSN it bogs at anything more than 1/4 throttle, which I dont mind at the moment, but it also doesn't get above 200* like that so I leaned it out to get it to run at all throttle levels.. It ran good like that, but it's idle is still too high.. From the needle settings it appears it's running like it should, for the needles being lean.. Only prob is, it wont run (yet) if I richen them up to where they should be.. Granted, I can richen the LSN and get it to idle fine while its running, but as soon as I try to introduce any throttle, it dies and wont restart until I lean it back out.. But I'm still hoping in a few more days it'll be ok? We'll see.. I'm up to about 1000-1500 cc's of fuel through it so far.. Thanks again for the help!
Scrogg: I'm running 20% traxxas fuel, stock SH pipe and medium SH glow plug (stock plug is also an SH medium)
