Well remember, the HSN controls fuel delivery at @ 1/4 throttle on up to wide open. The LSN controls fuel delivery at 1/4 throttle down to idle. So if you are going wide open and you let off the throttle....it's your LSN that is now controlling the mixture.
Here is a good test to perform:
-Start the rig up and warm it up on your starter box (or just something to get the wheels off the ground if you have a pull start).
-Warm it up completely to operating temp
-Grab a handful of throttle a few times, then let off the throttle completely.
What does the engine do?
1. Does the idle drop immediately down to a consistent and controlled idle?
2. Does the idle stay up fairly high for a number of seconds before falling back to a consistent idle? If so, how long does it take for it to drop down to a "normal" idle?
If you are in condition #1, you are probably OK on your LSN tune. With the car running, pinch off your fuel line. The engine should idle up and die pretty quickly, within maybe 2-4 seconds.
If you are in condition #2, your LSN might be too rich causing it to 4 cycle idle and burn off all the excess fuel in the crankcase...causing the idle to go way up until the extra fuel is burnt off...then it returns to normal idle. Lean your LSN 1 hour at a time until you get a consistent idle going. You should be able to rev it up to wide open and let off the throttle...and the engine should fall IMMEDIATELY back to a normal idle...or very close to immediately anyway.
Also keep in mind that the HSN controls overall fuel delivery to the engine. So if you lean the HSN, you are in effect also leaning the LSN by a tiny bit as well since the LSN pretty much overrides the HSN at 1/4 throttle and under.
It's a very delicate balancing act. Also remember, as you lean your LSN your idle will most likely go up, and you will need to adjust the idle screw accordingly to get a nice idle out of it. Never use the LSN to control your idle or you will end up overly lean.
