Dace Plate on Jammin X1CR RTR
Ofna1
Elmendorf AFB, AK
:redbuggy: Hello, has any one used a Dace X1CRT Rear Skid Plate on the X1CR Buggy ???? If so how does it work ? Did you use the factory screws or did you have to go longer ? Thanks:buggy1:
You can use the Dace rear skid plate for the Jammin X1 CR. I have seen them installed. I plan on purchasing this for my CR here soon. The one thing I am sure of is that it greatly protects the rear of the chassis, the one thing I am unsure of is if you use the factory screws to bolt it on. I would just order it, and if it comes with screws use those, if not use the stockers. Dace is really good at putting screws in there kits if needed. Hope this helps.
Tom
I think you will need screws that are about 2 or 3mm longer. I had the dace plate on my CRT and it helps a ton, the Jammin chassis wears incredibly fast back there without it.
Boy does it ever! After just a few races, my CRT is showing some signifigant wear. The plate is worth its weight. I need to order two of them... one for the CRT, the other for the CR.
Tom
Thanks Guys, that is what I did, I got one for the buggy and one for the truggy. I used the stock screws, our LHS is no longer open due to the internet.
