Cut crank engines in a Losi?
untchbl
Is there anyway to do it. I have to very new .12's that I've been racing in my gt this season, but am planning to go with a new Stadium truck next season. I'm still torn weather or not to get a new gt, or go with the mugen or losi truck. I think this engine issue might be a deciding factor.
Anyway around the cut cranks, without buying a new crank for the O.S. tr and mt.12?
Brandon
There is a way. Go to your LHS, and tell them what you're trying to do. You'll need a clutch shaft. (not sure exactly if that's what it's called) They'll be able to help you out.
Hey Nitro Gurus, bumpin this thread up to get more feedback.
Brandon sparked a thought in my head (not easy to do). I have tried without success to sell a NIB OS .15 CV-X w/cut crank. I have no need for this engine it came as part of a package deal I purchased.
BUT...... If for a few bucks I could make this work in my xxx-nt. I would keep it for when the Mach .15 bites the dust.
Thanks,
Mr T
From the research I've done, you have two choices.
Either you can buy yourself a new crank, or you can just lock tight the nut onto the crank and not worry about.
I'm going to do the later.
Brandon
Brandon, I'm glad you started this thread!!! I got to thinking that I had an old blown OS with what I thought was an SG shaft. I went home and started looking at it and thought hey maybe I can just use the shaft from the one OS and put it in the other to use in my xxx-nt. after looking closer at the ratty engine I realized it wasn't a SG shaft but a threaded shaft with adapter (can't think of a good name for it). None-the-less it screwed right off the old and right onto the new. The only issue is that instead of being held on by a dozen threads its riding on about 5 threads. Not much stress there so I think it will be OK.
Long story short...I went from having a brand new OS I couldn't sell to having a brand new OS back-up for my Losi and it didn't cost a dime!!!!
Mr T :cheers:
perfect. Just locktite those 5 threads and all will be fine.
Exactly what I'm going to do with my TR and MT12
Brandon
