without knowing what you are running 1 can guess what is the problem..Am has it issues but I ran it for 23+ years had a few run offs dint have failsafe's back then. FM also has its issues range.other interferance..2.4 is a great radio it has its issues also. seen a ir alarm system make dead-spots in out door areas and indoors...id check you radio gear. either take rc and place it off ground tied to something and test range..I've seen underground house main supply lines kill some rx b4 ...I have a setup to test my range on any new radio. ubec. a rx and servo with a fag mounted on servo arm. and stark the walk.. a range finder also.
