Connection to my Ez Start broke...
some_evil
Albury, Australia
hi guys, while running my Slayer pro today I broke the little steel clip that slots onto the negative terminal on my ez start. Does anyone know what these things are called to I can buy one and re-connect to my perfectly fine black connector? I would prefer not to replace the entire thing which is $10.
Any ideas??? See image for exact piece...
Cheers
You could try to find a new terminal like you would use for car wiring and then crimp it on... By the time your all done your better off getting a new one IME
an automotive connector will work fine for the repair. napa, advance auto, auto zone, WALMART even has some. take the one that broke off so you get the one with the proper width. they have many different sizes. put the cover boot back on the wire the right way BEFORE you crimp the new end on.
have any shrink tube? just shrink the wire side some so it has some resistance and leave the other end flared to act as a cover.
(you can run it without the boot anyways)
You can buy the entire harness on Ebay for like 5 bucks including shipping, i got one a few weeks ago. It required little work to replace.
i tried cutting the connector off and soldering the wire to the starter post. IT DIDNT WORK.
you could just solder the wire directly on the motor.
I don't think I'd solder it. Just go to radio shack and buy one and crimp it on. Easy to do
Sent from my SCH-I500 using Tapatalk 2
yeah I am planning a trip to jaycar to try to replace just the clip. The boot is long gone, ill just have to live without one of them.
Cheers
I like the ez start.
I would invest in a new ez start kit and have spare parts.
The gears inside do go bad...
Why not slap a pull start on it and shave some weight at the same time? Or a roto start?
I see a pull start cost about $12, what does the glow plug starter cost? I don't know what to look for when looking for them.
Sent from my GT-I9300 using Tapatalk 2
