Clutch upgrades for my maxx?
partbreaker
Always tweeking and wrench turning but I want weelies on demand! Whats my best bet, A 68 tooth spur, or an upgraded clutch, or both?? My slipper is set at back 1/4 from tight and my my throttle low end is set perfectly, what next?
Wrong spur. The stock spur is 72. I just went for a 70 to up the high end. Sort of reverse. The lower the spur, the higher the top end. If you're looking to do wheelies, you need more than a 72, but I don't know what's out there. Someone will post here with more info, but you can also change your clutch bell gearing.
They make a 76t that will work with the stock slipper, and RRP makes up to a 76t that goes on their double disc slipper. Or you can change the clutch bell to a 19, 18, 17, etc...
You want to go higher on the spur and lower on the cb I have a 18cb with mip clutch kit and 72sg and can do wheelies.
Depending on how old your clutch is, you might want to check for wear. A stiffer spring will raise the engagement too.
