When you take the glow plug out and no compression it doesn't do it, it pulls over lovely. It makes it stick sometimes and unable to pull very easy like it jams. Runs sweet as with no noise when started.
As you rotate or pull on the starter ,it is suppose to get tight like that ,that means that you still
got good pinch on the sleeve an good compression!
If you dont feel that ,then the engine is worn out!
Always run the piston down out of the sleeve at bottom dead after you run it when cool
down ,this will save the pinch on the sleeve ,an the engine will have longer life.
Pull the plug ,use a non metalic object like a tooth pic or zip tie ,run the piston all the
way down ,use the zip tie in plug hole to make sure the piston is down ,then put a mark
on the flywheel ,then after you run ,rotate your flywheel to your mark!...
