Cleaning
vbgagnon
RCTalk VIP
Madawaska, ME
Hey guys what is the best way to clean the crud out of the bottom of the cooling head? It is filthy all over the inside and where the glow plug should seal it seems to be getting chewed up a little bit. Any suggestions?
vbgagnon
I usually use denatured alcohol or a mild degreaser that doesn't eat plastic. Then a small bottle brush to get the heavy caked on grime - follow up with a little more denatured alcohol and then blast off with some compressed air. Typically it cleans it right up.
Personally, when my cooling head gets all gunked up, I:
1. Take it off the engine.
2. Remove the glo-plug.
3. Throw it in the kitchen sink with some soapy water and a scrub brush (bottle cleaner style).
4. I let it soak for a bit and then give it a good scrubbing.
5. Once clean, I use a hairdryer to get it nice and dry prior to replacing it on the engine.
Seems like a lot of work, but it works well and keeps the gunk from getting blown into the other parts of my truck. It also allows me the opportunity to check the internals of the engine and apply some ARO to the piston and sleeve.
