You need to set the charger for the kind of battery that you're charging, and the size of the battery and cell count, and it will take care of the rest. I think you're trying to use the default nimh setting or something apparently.
There's some instructions that come in the box with the charger and they'll tell you exactly what to do for every kind of battery.
I worked that bit out for myself, but thanks
: Bless you, I know you're only trying to help
FWIW I think it'd have sworn at me if I'd tried to charge a LiFe on the NiMH setting!
Oh and mine came with a cute note telling me to download the manual off the website, apparently they didn't include a paper copy because of 'time restrictions'.
Either way I read the manual at least twice before it even turned up anyway, so I knew pretty well what I was doing, but followed the words again just in case. I plugged the balancer in and everything, and it found it
I tried flicking through all the menus with it set to 'LiFe' mode, but there's nothing that lets you set the charge amperage. Like you said, you put the battery details in and it decides itself what to do.
It will charge up to six amps. It will peak charge the pack, which is what you want. You want it to cut off when the pack is fully charged, rather than charging by a preset time.
It'll charge at 6Amps *if* it doesn't exceed 50W. It'll manage 7.2V at 6Amps easy, and 8.4V at just shy of 6Amps but when you get into 3-cell A123s at 9.9V it'll only stagger up to about 5.05Amps.
Remember P = V x I - 9.9 x 5.05 = 50W.
If you use NiMH or NiCad it *will* let you set it to a higher amperage, but with A123 (and probably LiPo) it makes it's own mind up. That's fine for LiPo because charging at 1C is the only safe way, but it kinda sucks for A123, seeing as how the whole point is that it charges at high C.
It uses peak charging, and seems to work pretty well. As far as I can see it doesn't do timed charging. I might have missed that bit in the PDF tho.
Don't freak out when it goes passed the advertised mah. My 6000 mah LiPo packs peak at about 6400 mah, and the 2000 mah packs peak at about 2200 mah I believe.
Yeh my stick packs should take 30 mins from flat at 3Amps and are only 1500 mAh and went up to about 1780mAh and 32mins. As my dad pointed out though that's what the charger pushes *out* though, the battery pack drops some of it as heat and lack of efficiency.
You can just double the capacity rating on the Hyperion for your battery to force it into charging at 2C.
For example, if your A123 pack can be safely charged at 2C, and you have a 1100mah pack....set the charger to pack capacity of 2200 mah and the Hyperion will automatically charge at 2.2 amps.
AhHA! I thought this might be the way around it. Because it uses peak charging then it stops as soon as the battery reaches full charge, regardless of what mAh you tell it, right?
And for future reference, whatever sweetdiesel says about charging batteries, you can consider it law and write it in stone. He knows his electrics, better than almost everyone that I know.
Duly noted...
