Nevermind. I found one online.
This lip is what holds the axle in. There should be a bearing on the outside of this lip. Then the straight axle adapter goes over the bearing, preventing the bearing from coming out. If the axle and bearing comes out still, then a lip inside that adapter must have worn out.
that part is golden all good, i stripped out the end of the adapter (can't imagine how lol)
so it has no way to hold the bearing in place, i took the oter side apart and a glance was all it took to figure out what has been happening,
its an 8$ repair for another stock replacement,
25 for the branded aluminum adapters,
and 130 for the aluminum axles.
i want the alminum axle set both for the strength upgrade to my already pushinit axles, down low weight, and the just look kinda cool
but thats a lotta cheddar for me, especiall with the ryft coming in soon for me to buid
i think the ecto rear axle looks like it could fit then cen! i want to swap the axles but the ecto axle housing has shafts but no diff so that idea hit a wall after i took 3 seperate axles apart looking for parts that might fit to no avail.
but its as long as the cen axle is with the adapters, and the links line up!!!
