El Pirata
RCTalk VIP
Guess I have to take this then, I do like the breath comment.Originally posted by SkyMaxx
EP...I'm stepping out here...he's all yours.
Just clafifying here, so HPI .25, correct? Fired and used 1/4 gallon but now will not turn over even with the glow plug removed?Originally posted by Blah420
yes its a brand new engine,its ran about 1/4 of a gallon gas can,new glow plugs,its the.25 engine and I'm useing byrons fuel 20%
Is the engine still in the truck? If so is there ANYTHING binding on the flywheel?
If there is nothing binding on the flywheel, try turning the flywheel to turn the engine over? Does if turn over manually? Yes then the problem is somewhere in the rotostart. No then something is internally wrong and I would suggest returning the engine to HPI and have them take a look. If you opt against that and want to do it yourself then we will give you all the moral support we can from the net.
Does the roto start turn when it is not attached to the engine? Yes, then it could be the one way splintered and is causing the engne to bind. No, then check the battery connections.
Sorry to say so much here but LMK if any of these are present or not.
