If you're looking at a budget motor I've heard that you can't beat the Castle Creations Sidewinder 3 motor and ESC comboHi. I hope you are well. I have a 1/10 scale brushless Losi Tenacity T rig. It has been overheating lately and have heard that I should get a castle creations motor. Any tips on which one I should get? I run 3s.
I'm not sure what the stock motor in the losi is, but the sidewinder 3 is a 3800kv motor that's reliable. Higher kv means higher top speed, lower kv means lower top speed and more torque/accelarationThanks is the sidewinder 3 esc and motor significantly faster?
good to know for me too tbh, I had no idea ab thatThe castle 3800kv runs pretty hot on 3S. I ran that in my stampede with the sidewinder sct sv3 esc for a bit. Snapped the motor shaft off, then replaced it with the HW max10 sct/3660sl system and the motor also ran hot which is when I tried the 3665 motor. I may have to go down to a lower kv and gear up to get the speed I want without overheating with 20+ minute run times.
ThankyouI had read that the sct sv3 wasn't too great on a heavier vehicle on 3S. It did fine on 2S for over a year with the 3800kv. I'd run pack after pack in it. The motor shaft broke early on after I started running 3S, so I don't know how it really held up. But looking at the cost of replacing the motor (couldn't find just the rotor) vs trying the max10 sct/3660 system, I went with the hobbywing.
Also, the sct sv3 only puts out 5V to the receiver, so I was also running a BEC crammed into the receiver box. The max10 sct didn't need that.
I'll try and run it more this year with the setup I have to see how it does. Most of my time last year was taken up running my outcast and ERBEv2. I had strange issues with the max10sct/3665-3100kv the last run last year. I was either hitting LVC early due to tired packs, or it was overheating. I've built 2 new packs out of spare 2S packs I had with little run time on them, so the 2 7400mah 3S packs I have should be good and strong to rule that out as an issue. I also changed from traxxas plugs to xt90's, so should rule out current delivery as an issue as well.
I'm really jonesing to run something... haven't been out since December and with the weather lately combined with the covid thing... I'm climbing the walls to run RC's at all!
I don't think you want to go higher kv, that will likely just run hotter. You want the same speed or faster without overheating.What do u think about this esc motor combo?
Ezrun Max10 SCT 80A 1/10 3660 4300KV RC Brushless ESC Motor Combo Hobbywing RTR
if you get 1800 your top speed will be way to low especially if you're racing, I'd go with a 3400-3800kv motorCool thanks how many KVs should I get on my motor? 1800? And which pinion gear number?
