Carburetor and flywheel stucked - HELP RC Car Engine
Sickteddy
Hello,
I have a nitro rc car that wont turn on for some years. i had it stopped at my parents garage.
Now i want to turn on but i just realized, the carburetor don't move and the flywheel don't move either..impurities and dry oil on motor ?
I just removed the glowplug and the filter from carburetor, and threw oil to the holes... that would work?
What can i do more to put that motor working?
Thanks
rebuild carb(once you find OEM setting)... I've always used a non chlorinated brake cleaner. with a drop of Zmax.(love micro lubes)
Use a little nitro fuel to loosen up the carb and piston.
After run oil is best. But you can heat the block to loosen it up. remove all the plastic parts and carb and put in oven @ 400 digress and cook it for 15 minutes Use a vise grip on the fly wheel and slowly back and fort turn the motor to loose it more. Use after run oil.
