Rookie307
I have a Rovan 29cc Baja 5B, so I broke it in the other day! The brake procedure went as it should! I then decided to run it around the yard and, when I applied the throttle, the buggy would not bug. With tires on, or off the ground. I inspected everything in the ass end, and all looked good! So I got it back together and put some gas in it and got the same results! I geuss that is what I get for buying a Rovnofun, lol! While it ran I noticed that the Spur gear, and pinion gear where not moving! The hi and low needle have been set back to factory twice. I did notice that after the break in period, after engine cooled. The back with no tires on moved on there own for a brief second! I can only assume it is the clutch. I am at a complete lost. Any helpful advice would be appreciated!
