It gets Worse!!
I'm not sure but i think when the motor fell from the mounts it damaged something... When I start the car it runs a few seconds and then it seems as if something within the pullstart jumps and pulls on the pull start, then the motor cuts out... The guy in the local shop thinks that there is a problem with the one way bearing!! As a rusult I have bought a closed back plate and a starter box, so I can remove the pullstart. I am also told I may get extra power from the motor by doing this!! Problem being at the moment the flywheel sits to high therfore the starter wheel does not fit in to touch the flywheel. Gonna contact LRP and ask if the engine mounts for the team kit are smaller. If this is the case I will order this and my starting problems will hopefully be over!! Also it seems as the steering servo has broken... When i switch the car and the controller on the servo turns all the way to the right and locks in place!! got no clues as to why this is!!!
But most importantly, I need much help with this. When I start the car the throttle is completely in it may move half a millimeter further but no more!! But the car still wants to run off at a pace... If I use the trim to stop it running away the car idles too low and cuts out!! I really dont understand that at!! No throttle and with the breaks just pulling ever so slightly and its still pulling away!!! (my only idea is either that there is a problem with the clutch, that it wont release the axle at low rpm or I need to be tuning srcews and I'm not quite sure what the 3 different screws do, one of which I'm told I shouldnt adjust, and the book isnt too clear for a beginner like me.)
Any help is much appreciated, as you can imagine by now I am extremely angry and frustrated with the whole thing!! £800 and still not had it running longer than 10mins!!
As an extra note I have now secured all the screws and bolts I need with ptfe and thread lock, I dont think it would come apart if I wanted it to now ..lol. and when I said the shocks were bad perhaps I needed to let you know that if you push the car flat to the floor it only came back up less than half the travel of the shocks!! Basically they cannot hold the weight of the car!!
And again thanks in advance for any help!!
