Hey all. I'm building a 4wd 4ws truck based on a Clodbuster. I'm using all new hardware starting with a Super Clod Gray Edition. I'm using the kit supplied ESC which is a THW-880-Dual-RTR. The ESC, the gearboxes with motors, the tires and the body are the only kit parts I'm using. I purchased a Spektrum SLT3 3 channel transmitter with a Spektrum SR315 receiver. I'm using Arch Fabrication front and rear steering servo mounts. I have a y cable from the servos to the receiver. I have linked the transmitter to the receiver and it does steer both axles. However it crab steers. I figure I need to reverse the direction of one servo so I bought a cable for that. Now my problem is the motors do not run. When I turn on the ESC it flashes red and it beeps. When I pull the trigger on the transmitter no leds come on the ESC and no motors running. As I said, everything is new. I built a Clodbuster 20 years ago and I just hooked up everything, charged the battery and drove it. Still do in fact. Any help is sure appreciated.
