Can I turn up my D. Current?
Rip King MC
Earth
  2. Flying
My D. Current on my charger for discharging to storage voltage is set to 1.0 Amps, so it takes hours to discharge. Is it okay to turn it up a bit?
The battery that I'm discharging is a 4s 5000mAh 50c
I do not know what type of charger you have .. some dual bank chargers one can either hook a lead acid battery as power supply . of buy or build a resistor block.. chargers that be used that way are ichargers.or a few others .I built a discharge bank to do my larger cells...
https://www.rlpower.net/products/ic...harger-discharge-resistor-bank-silver-edition
you can discharge a lipo thru balance plug I think up to around 6 amps....
flysky discharger might work on 4 cells
