petal2thametal
RCTalk Champion
hi guys
i came across a new g4 evo2 at www.the-border.nl
the price =299euro. thats 399,62 dollar.
the parts you get in the box are
New steering k1480
- New steering blocks k1481
- Extra New clutch set k1410-1
- 4mm Lightweight chassis k1479 blue
- With the new Fuel tank k1419
- Carbon side plates k1439
- Carbon Front shock tower k1440
- K-factory G4 Front universal joints k1462
- Carbon brake bracket k1438
- Carbon arm stiffener brace k1442
- Hex wheel hub blue K1418
- Low friction belts K1402-k1403
- A set of standard belts
- Alpha front bracket for starter 111124
- Hard-coated alum. threaded shock
absorbers
- Teflon Pistons
- Lightweight M0.8 2-speed system (super efficient)
- Vented brake disc & brake cam bearing
- Soft belts & lightweight dust-free pulleys
- Lightweight pivot balls
- Light weight middle & 2-speed shaft
- Full high quality ball-bearings
- Low CG front & rear gear differentials
- Specially designed 5th body post
- Carbon Radio Plate
- Front one-way set
- 30mm push type clutch set
- Front adjustable anti-roll bar set (with alum. mounts)
- Rear adjustable anti-roll bar set (with alum. mounts)
my question is can i go wrong if i buy this kit.
iam looking for a pro rc race car that i can drive on the track.
is the g4 any competitive?
New steering k1480
absorbers
- Teflon Pistons
- Front one-way set
