Camo pattern w/ spray cans...suggestions?
PewPewChris
Georgia, USA
  3. Crawling
  4. Scale Builder
  5. Flying
I got a little Teton clear body while up at the HobbyTown today...I've got some black, I've got some green...any "easy" way to do a camo pattern with spray cans?
Liquid mask would be a really easy way to pull that off.
How so? I googled liquid mask...
like spray a base black down and then spray this liquid mask down in patch spots like camo and then paint it green and then peel off the liquid mask?
No, this stuff
https://www.amainhobbies.com/bittydesign-liquid-mask-16oz-bdy-lm16/p260637
If you're spraying a clear body, you'll liquid mask the whole body (inside now, not the outside), with around 5 or 6 coats with a fine, natural hair brush. Let it dry completely between coats (it will dry clear). Then cut out and remove the mask where you want it to be green and spray that. Remove the remaining pieces and spray the black. Then remove your window masks.
