Nitroaddict
Okay - I have a major race coming up at a local track on the weekend of the 30th. I had a race there a few months ago, and nothing i did would stop me from sliding all over the place around the corners. Not everyone had this problem, so it must be my setup.
The track is a semi-fast track with about 17 turns. It is paved with ice smooth blacktop.
My setup is:
52/50 spur gears, 20/23 pinions
gold springs rear, copper in front
4mm RH all around
1degree toe in front, 2 degrees aft.
2degrees neg camber all around
TRC 35shore front, 30shore rear, 26mm all around
OS 15 CV-R mill, with copper hard springs and a shaved clutch of 1/16th inch
Proline protoform stratus 2.1 body
With the low gearing and extra torque the clutch gives, i am wondering if that isnt causing the oversteer.
Even with me controlling the oversteer, i still have huge amounts of drift which is scrubbing off too much speed in the corners.
Could the problem be with the camber? I am thinking that with the track being so smooth, I'm not getting much bite in the turns, therefor, minimal body roll. Without the body roll, my camber is useless and is causing a smaller contact patch.
Would changing the camber to 0degrees help or hinder me?
My setup is:
4mm RH all around
