How much have you trimmed the chassis? In order to be lighter than a Cf chassis, that’s gotta be quite a bit. Let me see some pics of it with the body off. And also if you’ve trimmed it that much, and are concerned about weight, then why not get a different truck body? The Drag Slash body weighs a little over a pound by itself!!! I’d figure a Proline C10 drag truck body would only weigh around 300grams, if that much. Also, what kind of times are the Outlaw guys running, that you run with? If they’re sub 2.0, or right at it, you’re going to be at a massive disadvantage on a stock chassis. Electronics wise, it really depends on what pole motor you wanna run. Being rear motor, a 4 pole hanging off the back is going to give you even more rear weight bias, which will cause you to have to put more weight on the nose that usual. If you go 2 pole, stay between a 3.0-4.0t. Personally, I think a 3.0t or 3.5t is the best bet. But, everyone has their opinion on this. I just know those 2 different turn motors are what have won more races than anything. As far as ESC’S go, it depends on what your preferences are, and how much experience you have tuning them. Not to mention, knowledge about getting power to the ground. But regardless of your skill level, make sure that whatever esc you get comes with data logging. Without it, you’ll be chasing your tail, and taking shots in the dark with your tune and chassis adjustments. But throw up a few pics of the chassis and where you’ve trimmed it, and give me some ideas of what you’re up against/what equipment you’ve been looking into. Personally, I’m running a Castle MMX6S and a Tekin Pro-4 HD 6500kv Drag motor. It’s Tekins new 4-pole drag motor that’s comparable to the Castle 1412 6400kv drag motor.
