It "could" work. Its a cheapo rebranded Hobbywing V2.1 esc from 10 years ago. Seen a couple instances where the cheapo ones like to catch fire. That motor is a 4500kv which is way too much for a heavier monster truck.
I would look into the
Hobbywing 10BL120 G2 3652 combo. Or if it can fit, which it should but its going to be a tight fit, the
3660 combo would be more better since it has a bit more torque to move those bigger wheels.
The motor kv also depends on what battery/voltage you are running. If for just 2s, 3500kv-4000kv range should just be enough. You might have to gear down slightly. If for 3s, 3000-3500kv range with some conservative gearing will be good too.
