Well? That would be the first thing to check. Open it up and see what it needs.
do you pull one side of the frame off to get to it
I don't have stock TVPs on either one of mine, but I'm looking at 2 on top and two on the bottom. If I remember correctly, you'll also have to disconnect one plate from the rear assembly so you can spread them enough to lift out the trans.
It's NEVER the easy way for me. Why should HE get a break?three screws on the top, then the top comes off the transmission, then pick out the gears, be careful not loose the bearings, and thats the transmission.
you would think with that savage being new hpi would warranty the trans??
Write: HPI Racing
70 Icon
Foothill Ranch, CA 92610
Phone: (949) 753-1099
Fax: (949) 753-1098
Email: [email protected]
