Okay well today I was in the process of breaking in my brand new g-27cx supertigre and after one tank off the ground and the other two on the street on 1/4 throttle I noticed it was going through gas like crazy. I checked the temp and it was 196.7F and so it wasn't rich enough to be drinking the nitro like that. then i noticed after i filled it up i had a huge crack down the back side of my tank and it was leaking like a son of a bitch. should i just continue with the break in or start over?
Also are the supertigre engine suppose to run hotter then most engines or cooler. One guy at my lhs says hotter and the other at the same lhs says cooler witch one is right? I was told to get the temp to like 250 for break in and the other said 180ish. witch is right?
