kx250ryder
I ran my car (OFNA 9.5 Pro) today, it was about 85 degrees outside here in AZ. Because I hadn't run my car in a while, I put the Cipolla FZR .21 engine I have to factory break in setings to establish a baseline. That was 1/2mm idle, 3 out LSN and 4 out HSN. I did that by tightening the screws until they started to feel snug, and then backed out from there.
For reference, I was running the Dynamite MC-8 glow plugs and Blue Thunder 20% Sport mix.
The bizarre thing is that those break in settings were too lean, and my car was hitting 240-250 on occaision on the temp gauge (orange OFNA one) with the average around 230. I never even hit full throttle with the car, most of that was from driving the car in low to mid rpm range.
I have still been backing down from there, and just finally, after probably a half turn extra (or more) out on the HSN and LSN, got it below 200.
I had assumed that because it was warmer here in AZ that I would be leaning it out like crazy to make up for the air thinning from the heat. This seems like exactly the opposite. Any ideas?
Side note: I cannot get the engine to idle low enough to make the car sit still, I have to hold the brakes to keep it from idling away. I am running a standard clutch bell, with blue aluminum OFNA shoes and the gold springs that came with the shoes. Is this where drilling out clutch shoes comes into play?
