krzysiek
Hey guys,
I just recently purchased a Brand New Nitro R/C monster truck. I have been having quite a few problems with it so far, which is quite disappointing, it being the very first day that i've had it.
However, it was most likely due to some mistake made on my part, not the actual car itself being faulty.
At first i had trouble even starting the car, ended up that i had flooded it. So i unscrewed the glow heater, and used the pull starter to empty out the fuel in there. Eventually i got it to start, but i didn't have it tuned or anything, and as soon as it started it was going nuts, full ball.. had to cover the exhaust to force it to turn off as pinching the fuel line made it worse, i read that pinching it turns it off somewhere on the net.. meh.
So, i kinda figured that part out..got it tuned a little so that when it started it didn't go full ball, but just idled and didn't move..just right. However, it would usually die pretty quickly, like it could stay on for a bit, maybe a good 30-40 seconds, but eventually.. it would just die. If i tried giving it some gas, BANG - die straight away again. I tried this numerous times, trying to give it to heat up properly, etc.. but it still just wouldn't work, rather it just died all the time.
I then noticed that there was some fuel coming out the exhaust, i assume that this is just excess fuel or something, maybe from it not being tuned (problem above?) causing it to spit the excess fuel out..seems logical. But get this, the pull starter also seems to be leaking..not much, but its evident that there is fuel coming out of somewhere, as i finish wiping any fuel off, after a few unsuccessful pull-starts i notice there is more fuel there again. Is this usual, or have i received a faulty pull started out the box?
Now lastly, in a final attempt before giving up for the day, i went for my last pull-start, low and behold.. the string snaps. Yay! Now i'm left with the pull starter handle.. and the string thats obviously gone into the hole of the pull starter. Do i need to go and buy a brand new pull starter? I'm thinking just to unscrew it, pull the string back out, and retie it to the handle again..sounds good to me, what do you guys think?
Thanks alot for reading, really. I appreciate any help given, as i just spent what seems like a fortune for something that clearly doesn't seem to work for me I know its not the car, and that it's most likely me being a complete noob to all this, so no flames please
