Good reply
Only a matter of time I'm sure.
Yeah.. i have no knowledge on cars or nitro trucks.. tryin to learn a little lol.My theory is ,is a 2 stroke engine is a fixed port engine ,therefore it is not going to except any forced air
off of its own power ,its timing can't be altered an relys soly on compression!
However ,I think an engine can be designed to acomidate a supercharger ,a 4 cycle maybe a better
canidate!
If you want more power in a nitro engine ,your better off having it modded by someone!...![]()
Yeah i know if u start using higher percent nitro ur suppose to retune it. Not sure if id b so good and doin so. LolIn a high performance 1.1 engine ,they have a valve in which controls intake & exhaust ,some in which are modified
to be enlarged or even added valve ports to except more forced fuel & air ,so therefore the engines will except more
that is given!
A 2 stroke engine does not have that privaledge ,they are a fixed size porting ,also the engine block itself port channels
are the same ,so its hard to make changes in the port size with out messing up the piston timing ,a person can only
do so much to a 2 stroke engine.
But there is some modifications that can be done for a person to get the most out of what engine they have!...![]()
Well i guess i shouldnt make a thread on places to get nitro fuel then lol. I guess amazon.. seems no local stores have it that I've noticed. Best brand..?
Is that for a gallon? I actually bought some 20% traxxas fuel today.. yeah I've heard the weather change can lead to serious retuning... I'm so new to this.. its jus gonna b a live and learn situation. Lol.. I'm still reading into stuff trying to figure new things out.. for starters glue rims to tires and drill 1/8 holes at 12 and 6.. for the wet weather. Lets b honest my rig wont last a year ahahaha. :/
I really don't know who's post your quoting.You should use the little quote button on your right hand side!
I heard bad things about traxxas nitro fuel ,I've never used it ,so I don't know!
The fuel I use is $37.45 a gallon ,I don't buy it by the quart because its costly!..![]()
