Boca bearings special.
Foolproof
RCTalk Qualifier
Not sure if everyone knows about this or if I am allowed to post this but figure I will try to pass some savings on. Bocabearings.com is running a .99 per bearing special for regular replacement bearings. The whole kit for my Revo was $31 with free shipping. I figure I will put some good regular bearings in and get that Traxxas crap off my Revo. :D
Whats better...
Steel or rubber shields...???
I think the heavy rubber would be but not sure. Anything has to be better than what comes on them and for the price I figure why not.
so you got the steel ones then...???
They are the ones that work out to .99c each..
Thanks for the heads up too, I just ordered a kit for my Revo..
The only thing is I dont think they include the right sizes for my Rear RPM axles...?? Or do they..??
#58-200 is what I ordered. Not sure about the others. Do you know what size they are? if you do you can check it with the Traxxas parts list and see if they are the same. I should be getting mine in tomorrow. Ill let you know how they go in.
And you may be able to get some ceramic ones from TKO bearing. Thats where I got my clutch bell bearings from. Shipped they were like $7.50.
Rubber is better for exterior bearings. For bearings inside transmissions and such, metal is fine.
I use fast eddy rubber shielded bearings for all my needs. Tried boca's and they weren't bad, but at the time, weren't cheap for even their green seals. FE's are also $1.
I use boca when I need engine bearings. Costs more, but they seem to work well.
