Lean
whats happening is that the bearing craps out and it leaks air! When it starts going into 2nd gear it sputters and trips all over its self! no matter how rich you put the hsn it still does it! i took the engine out, covered the carb and exaust and blew air in to the fuel port with fuel tubing, then i put soapy water near everything that could leak and the front bearing was showing a leakage. i just replace the bearing with traxxas front bearings. i also tend to run my engine i little rich.
