Originally posted by SkyMaxx
I'd first check to see what the manufacturer of your engine recommends, and try those. If they don't work, I run long glo plugs in my big block engines. The plugs for the small blocks tend to die too quickly if they work at all.
I don't mean to pick on SkyMaxx or call him out, but this sniplet from one of his posts on a different thread spured me to ask this question that has been bugging me for a while.
If you've ever looked at the threaded end of a long glow plug and a normal glow plug, they are the same. You can swap one plug for the other and not have to worry the the piston is going to cause injury to itself on the glow plug.
That being said, someone at our track pointed out that the long plugs have more air space inside them (longer coil and longer coil compartment). Therefore, a long plug would produce less compression than a normal plug.
Another little piece of the puzzle clicks in when someone at the bashfest said that the guys at his LHS were playing around with different glow plugs in the Hyper .21 8-port. According to their research, the OS #A3 plugs work better than the long plugs that should go in the engine. This person's 8-port seemed to have pretty damn good power too.
I have only owned 2 .21 engines (8-port and OFNA force .21 / Savage / Lightning stock engine) and my experience is limited. What are the pro's and cons of running long vs normal plugs? Would I get more power if I switched to an A3 or A8 plug? Would I be doing any harm to my engine?
Thanks in advance,
Rob
