brokeitagain
RCTalk Qualifier
Just wonderin what you guys run or recommend. I wanna run a 6s lipo setupp on my flux now that I'm used to my 4s setup, but I want runtime and reliablitity. (Def don't wanna fry my esc with a cheapo battery.) I need somethin 25c or higher for those of you unfamiliar with flux. Also had a couple questions.
1. I want runtime to be as long as possible without overheatin the motor. Would I b better off runnin two 3s batteries around 8000mah each in series, or could I run two 6s batteries in parallel?
2. What's the most reliable brand for batteries, and will the charger I have b ok to charge a 7000 to 8000mah battery? I have a charger that supports up to a 6s lipo with no modification as it has balancing ports for 2s thru 6s, but its 5 amp max on the charge.
Also if it makes a difference I'm just bashin not racing, and while ill do the occasional standing backflip to show it off, for the most part I'm just doin donuts jumps, n high speed passes. Thanks for any advice guys!
