battery exploded
thats right, not all, but then again, i never said all.
edit: oh, and dont dodge the issue. you dont use bicarb with alkaline batteries. if people do say to do it, theyre idiots because they dont understand the 'complex' chemistry of batteries. as a year 11 student, i can't stress enough the simplistic concepts needed to understand the uselessness of using bicarb on alkaline batteries.
but heres a question for you, do they use alkaline batteries?
did it look anything like this when it was all said and done?
that WAS an ofna hump pack. about 2 months old in the photos. ran maybe 8 times.
13 year old DC charger never cut off when the battery peaked.. yikes
shoulda seen the damage in the engine bay of my bestfriends 94 sonoma show truck on air..
YIKES
Wow that battery lookes so messed up. If I only had a pic when the one in my car blew open, alt overcharged it so much.
yea theres only 1 cell in the picture..
literally, I'm not kidding
but 2 weeks later we cleaned the garage out and such.
and we found the other 4 cells.
most were on the clear opposite side of the garage from one another. found 1 in the bottom of a stack of tires.. whats weird was.. the top of the stack it was pretty much covered with enough stuff to be classified as it being "sealed"
yea very dangerous. keep your chargers up to date.
the battery destroyed the top of dudes yellow top optima and left a nastyy nastyy stain on his $800 grill
I had a similar incident with an old ProTech timer charger (around '91), when charging a stick pack. The timer went off, but it didn't cut the charge current, so it kept getting full current. The battery ended up eating a hole in the carpet.
The lesson learned; always charge on a surface you don't mind getting damaged.
YIKES
I've seen that somewhere before..... Oh yeah, I had the same thing to my RX pack ion my buggy that Jetmech sold me. The batteries shorted and blew while I was cycling them. To clean it up I just flushed the battery box with distilled water.
I've got an idea how to test if your chargers work. although i havent done it, i want to try, but havent got around to it.
ALL chargers charge at higher voltages than its batteries, so use a multimeter to check the output voltage.
using the equation R=V/I, where V is the voltage, and R is the resistance, I would be the current (must be in amps. if it is in mA, divide by 1000). check the amperage of the charger (I), should be on the label of the charger. then, use the equation to find your multimeter reading minus batteries voltage (V), ie; V=reading-1.5. When you find the resistance, go to radioshack or wherever and buy resistors that add up to the resistance (R). you want a variable resistor as well, then whilst varying the resistance, measure the voltage across the resistors.
find the voltage when the charger stops charging. if its above your expectations, either chuck it, or set a timer on it everytime you use it, checking the status of the batteries regularly during charging to prevent overcharging.
to check how long it takes to charge a battery, use t= Q/I, t is in seconds, Q is most likely in mA h. Check the amperage of your charger, and divide it. Do note what everything is measured in. if it has a small 'm' as in mA h, it is 1/1000 of an A h. CHargers usually give current in mA. Alternatively, and much simpler, you might remember how long to charge the batteries.
Batteries can usually handle overcharging for a while. dont test it, just dont panick too much if you forget to unplug the charger an hour later.
an example is a plugpack which says 720mA, and measured 12.40V.
recharging 1800mA 1.2V rechargeables. (i expect the voltage to be slightly higher, say 1.5V.)
12.40-1.5=10.90V
R=V/I
R=10.90V/(720 mA/1000)
R=10.90V/0.720A
R=15.138888888 ohms
R=15 (go buy a resistor around 10 ohms, and a variable resistor)
attach variable resistor with the resistor in series, ie end to end like a chain.
attach the set of resistors to the charger.
put a multimeter at the charger.
turn on the multimeter and charger.
twist the variable resistor until the charger turns off. take the last known voltage, say, 1.45.
CLose enough, the chargers fine. if its something like 1.53, id personally say thats too far.
say it was at 2.64V. its obviously broken, but i want to keep the charger.
t=Q/I
t=1800mA h/720 mA
t=2.5 hours.
at most, id give it a little bit more since its charging so fast, +- 45 min?
charge for 2hours 30min
and at max 3.25 hours = 3hours 15min
but check the voltage. this time is only a guide. if your batteries reach 1.5 volts, its good enough to turn off, and so check how long the charger was on. keep this time for future reference
hope this helps some people!
feel for you heartbreak. except, i checked my batteries, luckly!
Edit: Sorry everyone, big mistake, you must reread
