Balloons?
NJRC
Is there a right way to use balloons on your receiver and servos for water and dust proofing?
What exacting is the way to use a balloon for this purpose?
for the servos they are usually plasti-dipped (about $7 for a can) to use the baloon just put the servo or receiver through the hole and put a zip tie on it then run some silicone on the hole so nothin gets in. hen cut the hole for the servo horn and attach it. i have done it wihgt a baloon on the servo but i would imagine the baloon had enough flex that if you just screw the horn on the baloon wont break.
Plastidip servo's, balloons don't hold up that well when they are exposed. Get the 10" party balloons. Stretch the balloon out before trying to shove something in it. Once you've worked the balloon over a bit, stretch the mouth of it open and drop your receiver in it. Put a little dab of silicone in the neck of the balloon, then put two zipties and create a silicone bubble. That way you know it's air tight.
As for the servo's, just get a can of the plastdip stuff, take off the servo horn, put a screw in the output shaft so it doesn't get all clogged up, then dip the whole servo in the can by dangling it with the servo wire. Take it out, let it drip on a paper plate, but keep it hanging in the air somehow. Wait for it to dry, then dip it again.
Once it's all dry, trim off the excess around the output shaft with a razor blade and you should be good to go.
Hypedonrc said:
I don't no about you, but I'm leaving this alone!
Yep me too, wish i hadn't said it now. Some jokes are best left unsaid.....
(But a ribbed one would look funny)
What will happen next first I check out this thread on question about dying then I see another thread ballons & I'm thinking what the hell is this about & brainfarted I realized ok this other thread just screwed me up totally.I just can't decide which one has the better jokes
