nitro_desert
RCTalk Champion
hey my brakes are soo bad whats up with them??? the throttle and brake linkage goes all the way back so whats the problem? is there a screw i can tighten to make the brakes stronger?
I'm starting to wonder if reading the instruction manual would be a good idea? Maybe get a little background in mechanical theroy as well...
You dont' need to be a college grad to run one of these things. Just some patience, care, and general maintenance.
You lost a universal? dear god you have bad luck. When you get the new part make sure you put some threadlocker on that set screw so it doesn't come loose. While you're at it make sure all of the others are tight and have threadlocker on them as well.
