Black Scooby
I cannot get my backwash to go in a straight line when I accelerate, I've adjusted the trim but still with no success any suggestions please
As you check and inpect your parts for wear etc... I would be trying to get back to the stock settings if you can find those measurements in your manual. If not, with the stock set up, bring it as close as you can determine thru any track set up sheets posted by racers. If no info can be found that way, there is always the trial and error way. Once you have replaced any work parts etc, you have a clean slate to work with and a perfect reason to run your buggy for as long as it takes to get dialled in! There are kits available designed to help get very specific measurements on all of these settings. I don't recall where the discussion was in this forum, but lots of people chimed in. Seemed like a pretty good mix between people who like to set up with the kits and those who like to do it by feel.The toe in, on some cars, is sometimes factory set and not adjustable in the rear. That's to keep the rear following and keeping it from getting squirelly.
The front tires should just toe OUT about a degree or so, to make it corner nicely.
