Austin Merritt
Hey everyone, I'm new to this forum, and relatively new to the hobby. I have a Duratrax Maximum BX Buggy that I am in the process of resurrecting. Before I get all the "Stop, it's old and not worth it" replies, I'd like to say that I've had this for about 7 years now. Maybe 8. My dad bought it off a guy he worked with and brought it home out of the blue one day when I was younger. We ran the thing so much and had a blast with it, but then the pull starter broke and it sat for a while and we moved to a new state and it got forgotten in a box for the last four years. So that is why I am putting the effort into fixing it instead of buying a newer, nicer car.
The car has a Torq .16 engine on it. The engine IS free, even after sitting for so long. My dad and I put a Tiger Drive on it after the pull start broke, but I don't think it has ever successfully started the car. I took it to a local shop and they did a compression test, which showed around 50 psi. That sounds good to me, and the guy who runs the shop said that is fine. I cleaned the carburetor and put a new O ring on it where it attaches to the... I guess engine block? No leaks, and it is set to the Duratrax recommended settings. Brand new glow plug. Fresh Nitro. However, I cannot get the car to start!
I am using a Makita 18V cordless drill to try to start it with the tiger drive. The fuel appears to be going in the right place when I open the throttle and watch when I prime it. I've tried heating it with a heat gun. I've checked the igniter I have with the new and used glow plugs I have. They are all bright orange.
Any ideas on what else may be wrong with this? Anything I have missed that might be the cause of it not startring? I've been watching videos and reading a lot of things about the no-start issue and they all seem to say the same things.
Any help/advice is appreciated!!
Bottom line is that if the crank-case is seeing fuel, the engine is turning over, and the glow plug is getting hot, there will be combustion if not but for a small number of causes. The crank-case is getting flooded, in which case the piston will almost always get stuck and the flywheel will be extremely hard to turn. Empty the engine of fuel by removing the plug and turning over the engine a bit (preferably holding the car so fuel doesn't spray you in your face). You are getting to much air in the mix and bad compression. Backplate isn't tightened properly, head isn't tightened properly, glow plug isn't tightened properly, carburetor isn't set up and or tightened properly, exhaust not seated properly. If the air leaks/bad compression issues are small the engine will typically still run but you will have trouble getting the engine to hold a tune or stay running for long. One more thing that just sprung to mind, when you turn over the engine with your drill, are you sure it's engaging the crank and actually turning over the engine? Try this, do not prime fuel to the point of it hitting the HSN nipple, turn the engine over with finger over exhaust, does the fuel move into the carb?
