Overdrive (commonly referred to as ‘o/d’) is a rock crawling thing. Overdriving the front axle makes the front wheels turn faster than the rear wheels, typically by 5% to 15%, but there are implementations out there of up to 33%!
Overdrive can be achieved by driving the front axle faster or the rear axle slower. Ring and pinion gear ratios can be changed so the difference happens on the axle at each or either end. Alternatively some transfer cases have a provision to drive the front faster than the rear, such as the StealthX transmission from Element RC’s Enduro line.
Overdriving the front helps the vehicle maintain direction on difficult climbs where traction is low. It does this in two ways:
- It lets the front pull the rear onto and through problems.
- It also maintains a low loading effect on the suspension by way of that front/rear wheel speed difference. This is thought to aid traction on rock problems, though it would be undesirable on flat, high traction surfaces.
On steep ascents without overdrive, the rear has more of the vehicle’s weight on it and so often has more traction available than the front axles. With that extra traction, the rear will work to push the vehicle forward. This hinders it from turning in whatever direction you’re steering. It’s like a slow-motion, understeer effect that is undesirable on rock problems.
