Out flogging the crap out of this with a mate & his Losi 8t - results over 2x bash sessions:
Fubar'd pipe & bent throttle linkage from a collision, broken bumper mount from another collision, broken rpm front arm as well. Broke the last of the cheap ass metal driveshafts, was running 3x stockers & 1 metal, both of the rear stock driveshafts are almost torn through the plastic joints.
Had a destroyed rear diff side bearing.
Chassis has held up well to several spectacular carwheels on a rough bitumen carpark.
The RR slipper is fine now, looks like the chassis was the culprit to chewing them out.
I tried an 086 pipe on the Picco to replace the busted GO pipe - Picco hated it, would not rev out, no top end at all, stuck a GO 2072 on it & it came alive again.
Since I last updated this it got treated to a big ass spectrum digital steering servo, massively powerfull, the old digital steering servo went into the throttle/brake spot.
Also rubber mounted the roll bar so it doesn't bend the chassis when my driving style results in a high speed cartwheel.
Mate with the Losi (Punisher on here) wanted to quit his Revo, so I grabbed it, it's got some nice bits so mine will score the best stuff from both, the rest will be used to build up a 'spare' Revo with a .21 in it that won't smash stuff all the time, my son can use that & I'll have it for a spare when I break mine.
I've got another Revo 3.3 I built from spares that'll get sold as a runner with a few updates to fund the latest purchase.
Rebuild will start tonight with a can or 2 of JD, should turn out to be pretty much the ultimate revo:
Vantage carbon fibre chassis
Picco .28 team turbo, BB buggy header, GO pipe, running 30%
Motosaver filter
Qconcepts mount
Custom throttle linkage
Losi 8t clutch with aftermarket offset hard alloy shoes & 18t RR bell
RR slipper
Full RR std ratio trans gear set, custom case hardened 8740 steel main shaft
Custom steel centre driveshafts
Brushless ERevo diffs with hot racing billet cups
TRX steel driveshafts
23mm hex conversion
RPM true track rear & front arms & carriers
TRX alloy pushrods & drag links
Alloy single servo steering arm
GTR shocks with TRX tuning kit, blue rear springs & silver front
TRX sway bar kit
TRX P2 rockers
RPM front & rear bumpers & mounts
TRX wing & wheelie bar
Techno battery box, RX box & fuel tank conversion
250cc Hyper 1/7 tank - with modded cap seal so the dang thing seals.
spectum steering servo, powerHD throttle servo
Custom rubber mounted chromoly roll bar
Choice of 40 series road rage tyres or bow ties for bitumen or dirt
Before pics as it sits this morning, I'll give it a clean up along with the donor revo today:
