Aquacraft Supervee 27 Nitro
Rapid City SD
  2. Crawling
  3. Boating
Picked up this bad boy last week. Reset the carb to factory settings, messed with the idle gap a little bit and she fired right up. I added the pool noodle. Broke the radio box trying to remove it to clean up a little bit, looking over the thread on RCU it appears the radio box was rather fragile anyway. Gonna take it out this weekend and see if I can get it to hold a tune. My plans are to fix the nose then repaint it, probably fluorescent green.
What are you going to patch the nose with? Don't know much about rc boats. Is it a plastic shell or a fiberglass hull?
It's fiberglass so I basically need one of those patch kits for a real boat. Still need to look up the painting aspect though.
Fiberglass is pretty easy to work with. I would grind some of the area behind the broken area down so when you lay the glass fiber it can overlap the edge of the crack about 1/2" or so, to prevent it from cracking there again.
You might be better off not even using the glass fiber. I used to build speaker enclosures with bed sheets and they were plenty strong.
Cool boat and good luck with it.
Do you have a recovery plan in case she stalls out on you?
I have a paddle boat out at the lake.
Looking at it it does seem like I only need the filler and gell coat.
That will probably be just fine for that spot actually. I'd still feather the edge back a bit so your crack doesn't return.
It does have a small crack that goes back a little bit on the one side.
Good time to sand her all down and apply a Miami Vice paint scheme 😉
It would help if the parts looked like the drawing, hard to tell, but yep looks like it's press fit. How do you pull that apart without damaging it. My inexperience is showing, isn't it? 🤔
Put a nut on the crank threads. Heat that aluminum collar up up and hold onto it with pliers and tap the nut you put on the crank. It is probably just seized on there.
@Chubaka @Littlemotor any idears?
I’ve been hunting a proper flywheel puller for this for the past hour with no luck… It’s a tiny, little, sweet baby Jesus .18… on top of that-it’s a tiny, little, sweet baby Jesus marine flywheel… annnnnnnnd, it’s aluminum over steel with a brass collet… So heat, and/or cold isn’t gonna be a ton of help.
I don’t wanna be the bearer of less than awesome news here, but I’d be willing to bet, it’s gonna involve some caveman shiit…
What really sucks is that you don’t wanna scar up your spotless aluminum flywheel, and that’s gonna require some serious thought, and then even more seriouser patience, and steady AF hands… while a crankshaft SHOULD be plenty “hard”, I’d for sure be afraid of damaging the threads even with decent engagement of a nut… If you go this route, I would advise against grabbing the flywheel. I would sit the crankcase on a block of wood with the crankshaft perpendicular to said block, and place something reasonably hard directly on the end of the crank, and give it a medium whack. OBVIOUSLY not something metal (or harder than the crank), so that you don’t fold that last thread.. Obviously this is after removing the set screw from the flywheel if there is one (I see the flat in the crank snout in the diagram, so it’s possible).
The only thing I’d be worried about is splitting the cast aluminum crankcase, but with a medium whack, and the case perpendicular to the block of wood, this will be the safest procedure without access to a proper puller IMO.
FWIW-there seem to be an assortment of different setups; some involve a “keyed” flange as you made mention of, and some use a collet.. Some look like BOTH.. either way-once the flywheel nut is out of the picture (as shown in your photo), and any set screw in the flywheel has been removed, it’s simply being retained from the flat, or flat(s) on the crank snout, the grip of the collet, or both. There’s no amount of heat, cold, or penetrating lubricant that’s gonna do anything at all-it needs mechanical “persuasion”.
Since it does look like it has a set screw hole in it, it is probably just a slip fit on the crank. It is probably just gummed on there, or maybe a little corroded.
I tried the nut but didn't use any heat.
I picked up a battery terminal puller as that was what someone had suggest to use as a flywheel puller for a normal flywheel. Gonna test it here in a minute.
Not a set screw hole, looks like it had some material removed there to balance it out.
