anyone running a nomadio radio on vista?? help!
beason
Bash, Fix, Repeat..
Webster, TX
ok so i got new rigs and i need to update the profiles on my sensor. I downloaded the new desktop software and found the vista driver. the software works and the PC sees the radio, but every time i try to retrieve the settings from my radio i get a java se platform error.
WTF!!
Format C: .... ~~~
Install XP
J/k........
You should get a program called javara. This gets right of the old versions of java and makes sure that you have the most up to date version. If that still is not working for you I suggest that you go to add/remove programs and remove anything java related and go to http://java.sun.com/javase/downloads/index.jsp and get the newest JRE. If its still not working you could try to right click the application shortcut and enable xp compatability. If its still not working try contacting the company and see if they want a certain version of java for their software. Sometimes certain apps are real picky as to which version you have. Good luck.......
Format C: .... ~~~
Install XP
J/k........
i have installed the latest java jre and jdk. i have tried all the compatability modes, the company is... hard to get ahold of...
guess ill try the javara thing. link?
Veesta has huge issues with Java. And I'm thinking about rolling back to XP myself. Veesta is too bloated for it's own damn good, typical MS crap.
