Just *tried* to break-in my FR18 today, and was faced with all sorts of issues.
First, with stock needle settings, the engine would cut out during the required idle-to-WOT passes. OK, figured it was too lean (dont know how, these are stock needle settings, not touched). Richened it up, no more cutouts.
Second, after getting it to run with no more cutouts, after 1/2 tank it stalled. Unable to restart it again for a while (cleared it out in case it was flooded, etc), I took it to an LHS. We were able to get it started and idling, so I took it back to my break-in location
Third, started right up after getting back to the break-in location. Made a couple more idle-to-WOT passes, then it stalled. After another 10 minutes of trying to get it to restart, I decided to look at the plug. Sure enough, I pull it and there are black shards of something all over it. Pretty good considering the engine is sealed and the air filter is on so tight I can't pull it off by hand. Pulled the head, and sure enough again, more shards and the sleeve is scored.
I'm wondering if anyone has recently gotten an engine that did the same thing. Keep in mind, I wasn't even able to run a whole tank thru this thing. I hope Fantom helps me out, I've already contacted them.
-Chris
-Chris
