militarymaxx
Weather was good, finally got out after many months without running. I went back to the factory settings on my RB CE engine,
(3.5 turns out HSN, 5 turns out LSN). It ran great for a little while then as usual, it would die if I burped the throttle, high speed runs it would bog down and die. I read somewhere that the RB CE engine runs good at 3 turns out on the LSN and the HSN is flush with the barrel. Going to try that. After running I have little droplets of fuel collecting on the inside the air filter intake tube.
Is this another sign of running too rich and if so, is it on the LSN or HSN side, or both. Also, tell me what you think about the 3 turns out LSN and flush with the HSN. Thanks.
