I've used stock plastic (crapxas), integy and ACNCM. ACNCM being the cheapest al ones I could find, were way beefier than the integy's. I had a severe (really severe) crash a couple days ago. All 4 skid plate bolts on the front were sheared off, all 4 hinge pins were bent (titanium), a big nick in one of the bulkheads from the concrete curb I hit at WOT, but they aren't bent. Couldn't get the remaining part of the screws out, so i had to replace the bulks. Ended up with another set of integy's. It was $29 for integy, or $69 for dynamite (LHS). Can't beat the price for integy's since dynamites are basically the same.
Another thing you have to thing about with al bulks is hinge pin wear. RC-Solutions found a way around this by putting a set screw on the pin so it doesn't rotate. I mod'd my integy's i just put on to do the same. Although, integy doesn't have that cool connector plate that helps the hinge pins not bend. Just by looking, I'd have to say RC-Solutions are going to be the best for the $. Long life, no wear and good design adds up to no replacement. Unless you shear the screws off like I did, then your kind of "screwed" (pun intended).
Anyone know how to get a sheared off screw out of aluminum that was put in using blue locktight? Most of my screws are of the stainless type.
