You don't want to listen to me... I'm cheap! I buy whatever is cheap that I can find more good than bad info about.
This is the engine I've seen run:
http://www.horizonhobby.com/Products/Default.aspx?ProdID=DYN0895
It's not bad and it's much better with a different pipe than stock. With the JP-2 pipe in a muggy, it really rips. With the stock pipe on a LST2 (which is better than a AS stock pipe) it's kind of a dud. The stock pipes for all three (AS, LST2, Muggy) are pretty lame. Which is too bad.
You have the aftershock right? That has a M26 in it (you said mach 27?).
The Mach .28ci is 4.588 cc. The Mach 427 is a .26 ci engine. I think it's just a dressed up M26 that comes with a roto-start on it. Although, the M26 parts list only has DYN part numbers listed for half of it. The rest of it are LOSI part numbers... Who knows...
The platinum 28 has a little bit higher HP rating but quite a bit higher RPM range... It costs a lot more though.
Is your engine on it's way out or are you just looking for more power? The one you linked too should have more, not a lot, but it should be noticeable. With a more open pipe, it would more than likely have quite a bit more. Also, the one you linked to should drop right in with the parts you take off your stock engine.
I've read that quite a few people have bought the LRP Z.28 and have really liked it. Not many with an aftershock, but in revo's and savage's.
http://www.killerhobbies.com/items/...c-3-engine-asclrp32802-asclrp32802-detail.htm
