after run oil
harry
RCTalk Racer
ni
hi guys,
i was wondering is the after run oil any good?and do you realy need it?
what does it do?whats the best 1 to buy?
thanks
Yes you need it.
Nitro fuel will attract moisture. The ARO will displace any moisture and keep the piston, sleeve and carb lubricated.
I always used Fantom RIP Saver due to its convenient application tip it has on the bottle.
I run Hobbico ARO as it was the most popular on amain and it works fine for me. Has a nice tip on I think any of them will work fine though.
Doesn't matter, they are pretty much all the same. When you are done running, pull the glow plug out, put a couple drops of after run oil in the hole, turn the flywheel a couple times and stop at bottom dead center, (just make sure it feels loose, not tight) then put the glow plug back in.
