Originally posted by militarymaxx
I finally have the courage (and skills I hope) to enter an official race. To make matters worse, it's on a track that I've never put so much as one lap on, and it's one of those two day events,
(qualifying all day Sat, and racing on Sun). I plan on spending all day Friday putting as many laps as I can in to get use to the track.
The track that I normally run on is short and technical. The track I will race on is much larger, bigger doubles/triples, more washboards. Oh yeah, there will be more people on it than I'm normally accustomed to as well. My goal is to simply finish. What I need from the experts is a checklist. I'm bringing everything I have, tools/parts, etc., but would like to hear from the folks who have done this before. Appreciate all the help.
Okay here we go (I may miss something but it should be a good start):
1. Trickle all glow chargers over night (I have three glow starters 2 rechargeable and 1 with powered by NiCD bring a spare battery) to make sure they have enough juice.
2. Trickle charge starter box for 8-12 hrs depending on your gel cell type.
3. Charge or replace Tx & Rx batteries (bring spare set if you are using Nicds)
4. Rebuild all diffs if you have not done so in awhile
5. Rebuild shocks (rebuild kits are cheap)
6. Get extra oil for shocks (if your shock bleeds out you can quick fix it). Also get a couple different weights in case you need to change it up for the track.
7. Check turnbuckle ends as well as tie rods for wear and replace if the tie-rod is bent
8. Visually inspect spur and clutchbell for damage (Repair as needed)
9. Visually check clutch shoes (Repair as needed)
10. Check manifold and pipe for good snug fit (You do not want them to come apart in the A-main and ruin all your hard work for a 2 minute fix)
11. Clean Air filters (bring one spare if you have one)
12. Check to make sure carb is tight...you do not want fuel spraying all over the place
13. Visually inspect the entire car for cracks and/or other damage (Repair as you deem necessary)
14. Loc-tite every DAMN thing you can with Red loc-tite (color of the actually compound is blue) and let cure for 10-15 minutes (Replace stripped screws as necessary)
15. Inspect tires for wear and call ahead at the local track to see what tires they are using. Bring all the tires you have for your buggy and if you find that your buggy hooks up well with a different tire than is mentioned stick with your tire. If it ain't broke don't fix it.
16. Bring at least two extra glow plugs of the brand you prefer (I use OS #8 but as I said that is my preference).
17. Check all screws and washers for a tight fit but make sure there is NO binding in the suspension. The suspension arms should go the full range without ANY binding. Adjust to make sure there is no binding in the suspension.
18. Before qualifying loc-tite all the screws which have come loose during pratice. Also check all screws to make sure nothing has backed out during your pratice.
19. Have your fuel guy pratice fueling up your ride and also have him keep a set of pliers in his pocket in case something needs to be snapped back on.
20. When praticing watch the faster guys and study their line. You will find the guys at the head of the pack usually take the same line. After watching the line and brake points get out on the track and follow the faster guys....there is no need to pass you are trying to get a fast line around the track. Remember you are racing the clock not that guy in front of you.
21. Tune your HSN at the beginning of the day and once you get a good tune do not over tune it trying to exact the last one percent of performance out of your engine. If you have a nice stream of smoke and good power you should spend that time praticing on the track.
22. Make sure to have fun as that is what everyone should be doing.
23. Slower is sometimes faster. Stay in the middle of the track and roll the corners. Nobody ever caught a pipe when rolling down the middle of the track.
24. Have fun! Good luck and I hope this list helps!
