The vintage reds are oil shocks. They are anodized aluminum right? There are o-rings around the shaft in the lower cap to seal the oil in. If you run them without oil, you are going to wear those o-rings out.
Yea my kyosho pro X shocks are oil filled. Need oil in shocks for damping and lubrication.. If the shaft get really dry with no oil the springs will have a hard time rebounding.. but they also use a different oil thickness scale. Then the USA oil wt. Scale.. I run. 30wt in my Pro X...
