A Big Kid
- Old Hangtown U.S.A.
- Crawling
- Boating
In my ARRMA Kraton crawler I originally set it with a 2250kv 3542 1/10 scale Outrunner into a planetary gearbox. Now this has worked just great and even tho my rigs near 17 pounds due to such Low low gearing the little 1/10 motor hardly breaks a sweat and has more than sufficient torque.
** Issue is top speed set up as such being @ 10-12 mph at max throttle, might be a tad less than that as it certainly is not faster
* Picture below of the 9IMOD 3542 size Outrunner and gearbox combo.
So ... been searching and searching for a LARGE Outrunner utilizing 5mm shaft output in an @ 42mm diameter ( Same as an OEM BLX 2050 kv ) and came across some Large Scale Aircraft Outrunners ( Marketed as Aircraft but also general use ) that met the wanted specification. So for $30 bucks took the gamble and ordered up the 4250 size in a High Torque 560kv format. * Idea here is to still gear low but run as a direct drive as rig was designed to use.
** Reason I'm staying with Outrunners is COGGING or a near lack of being Outrunners utilize 14 pole 12 slot stator/windings and deliver power very smooth and linear over a conventional Inrunner design. A Very Low 540 KV I'm thinking might be very controllable as well ?
I hope my thoughts align with reality in that set up as such The low end torque will be there in mass, while more topp end speed might result ( Want to stay sub 20mph ) can motor pinion up as needed ... i think ?
Any thoughts ? ... or am I nutz
