5S Powered Arrma Mojave XLX2
JapanRCAdventures
Here is my All Carbon Towers, Chassis, XLX2 TP Powered Sensored Arrma Mojave riding on 23mm hex Integy wheels, Titanium hexes & center drive axles, Carbon Fiber wheelie bar, Trimmed fenders, Perfect Pass servo, Adu Racing Center brace, Custom
ESC mount to fit the XLX 2 in the stock position, GP5 Diffs, Carbon Fiber Mud guards, High speed 8v fans, Wireless receiver. Titanium suspension hinge pins and pivot balls, titanium shock stands. Enjoy the snaps
Thanks. Rubber grommets not used just trying on when taking the snap. Cause no one else
has done 5S :)
Cool. I solid mounted my 50kg Power HD to my JBI mount in my K6 w/ Reefs servo washers, the ones w/ the boss on the bottom. No issues.
5s, I guess the ESC recognizes it as some ESCs do not, either 4 or 6. I've run my Noto on 4 & 6, and prefer 6s. Lots more throttle control throughout.
Sounds like a stout set up indeed 6S is always a solid power system. The Castle systems recognize 5S. My aim was to have 8S controlled Power ( its a TP 5840 sensored motor) without the added weight of running two 4S Packs. Mission accomplished on 5S (its a high KV system putting out over 300amps continuous hence the XLX 2 as the only esc that can handle the amp draw. So its lightweight, overpowered and sensored (i race on the tracks with 4S). The truck use to be 8S and now it handles like a 4S and runs hard like an 8S.
Nicely done, looks good!
Thank you!
